조회 수 384 추천 수 0 댓글 1
Hello, customer
Thank you for your interest.
If you do not have the remote controller you requested, please send us your remote control and we will check it after input. Also, if you have a remote controller, please send it to us. Most have been repaired to this day. Please use a lot.
Or let us know the product introduction or purchase link (site) and we will consider purchasing it actively.
If you send a photo of your remote control with a higher resolution, it will help you to work.
If you operate from a third party app on the remote control, you can capture the app screen and send it to us to create a profile. Please use this method.
For example, if you want to search LG TV AKB73275619, please search AKB73 or AKB7327 to find a similar remote. It is also a way to search a little of the remote control model name you are looking for. I hope this method is also a favorite.
You can also search for "air conditioner" as "Samsung Air Conditioner" or "LG Air Conditioner".
You can easily find the remote control using the auto transmit test on the remote control that has been searched.
On the other hand, you can input it with my remote control dongle (http://item2.gmarket.co.kr/Item/DetailView/Item.aspx?goodscode=334920433)
There is a sample Hangul video (http://www.myremocon.com/index.php?document_srl=61449). Please use.
 For information on how to add a function button (http://myremocon.com/index.php?document_srl=61446) that does not exist on the remote control of the device, such as how to find the remote control when you know the manufacturer, please refer to it.
1. How to find remote control when you know the manufacturer (How to find remote control when you know the manufacturer)
Http://home.myremocon.kr/myremocon/image/remocon_search.png
2. Modify the button's attribute data on the remote control (the remote control data)
Http://home.myremocon.kr/myremocon/image/mod_attr.png
3. How to add function buttons that are missing from the remote control of the same device (How to add new function buttons)
Http://home.myremocon.kr/myremocon/image/diff_search.png
4. Samsung S4,5,6 Note3, 4 and LG g2,3,4,5, V10, V20 with built-in sensor can be used immediately without a dongle. Some Xiaomi phones are also available. Galaxy Note 5, S6 Edge Plus, and S7 and S7 edges do not have sensors inside.
Also, LG ViewTo is not supported because it does not support standard API. If the dongle does not work, please re-mail it.
If you have difficulty typing, please email me (webmaster@signzzang.com) and I will answer you.
Thank you.
Send to: 648 1308-1 West Busan, Geumcheon-gu, Seoul, Korea (6th Daehung Techno Town) My Media
Phone: 02-866-1173 Postal Code: 08504
Yoo Seung Hyun Compensation
    boroz 2018.04.10 12:00
    I have a problem with the use of REDMY 4X DONGLE
    RECEIVER DOES NOT WORK
공지 마이리모컨 앱 메뉴별 동영상 메뉴얼 입니다. manager 2019.01.25 243
공지 무선리모컨(도채비)을 2G와 5G에서 모두 사용하기 위한 방법 file manager 2019.04.27 146
공지 앱에서 음성명령을 쉽게 사용하는 방법에 대해서 manager 2019.04.24 79
공지 무선리모컨 도채비를 등록할때 잘 안되는 경우 조치사항 file manager 2019.04.14 171
공지 마이리모콘X 동글 사용을 위한 폰 환경 설정에 관하여 file copyremocon 2014.11.20 423823
공지 마이리모콘 폰 환경 설정에 관하여 (20190515) file copyremocon 2014.11.20 426386
공지 마이리모콘을 시작하기전에 한번 읽어 주시면 감사하겠습니다. (20190515) copyremocon 2016.11.29 42022
공지 리모콘 요청 및 질문 공지사항 10 copyremocon 2014.11.18 2839
83 마이리모콘을 시작하기전에 한번 읽어 주시면 감사하겠습니다. copyremocon 2016.11.29 38085
82 리모컨 요청해봅니다. file 진놀 2019.03.30 62
81 한라웰스텍 HTL-327PS 리모콘 파일 요청드립니다 2 열정해피맨 2019.03.19 41
80 이거ㅠㅠ 1 file dkr 2019.02.26 65
79 삼성하우젠 AVXC4H072B3 리모컨 부탁해요 1 file 응가 2019.01.03 77
78 리모콘이 없는 스피커 살릴 방법이 있을까요? 요즘 날도 구리구리하고해서 집 정리를 하다 베란다 구석한켠에 의미없이 자리만 차지하고 있는 박스를   열어 보았더니, 리모콘이 없어 사용을 하지 못하고 있던... 1 블루레인 2018.07.03 314
77 리모콘 요청합니다 1 앵두앵 2017.11.15 561
76 문의/건의사항이 있습니다. 1 copyremocon 2017.02.23 418
75 중국 샤오미(Xiaomi) 미맥스(Mi Max) 기종을 쓰는 사용자인데 잘됩니다. 1 copyremocon 2016.11.22 597
74 マイリモコンプロファイルの作成に関する文です。 copyremocon 2016.11.10 533
» My remote control profile creation. 1 copyremocon 2016.11.10 384
72 내장센서가 없는 폰에 대한 설명입니다. copyremocon 2016.11.08 3335
71 마이리모콘 프로파일 생성에 관한 글입니다. 1 copyremocon 2016.11.08 1095
70 갤5에서 잘 사용했었는데 갤럭시7에서는 실행하면 화면이 거꾸로 돌아갑니다...너무 불편하네요...방법이 없을까요? copyremocon 2016.11.08 579
69 캐논dslr 리모콘, 캐논, 아주간단한리모콘모양, 캐논5Dmark3 copyremocon 2016.10.12 180
68 리모컨 1 으잉 2016.08.22 312
67 이동식에어컨 윈스 kc-20y 제품 리모컨 요청합니다 1 김택순 2016.08.11 219
66 지프로2 작동이안되서 첨부파일보냅니다 3 file 응가 2016.07.06 907
Board Pagination Prev 1 2 3 4 5 6 Next
/ 6
